Lean Transfer Machine PICCOLA
PICCOLA CNC Lean transfer machine, extremely flexible and productive, able to perform boring, milling, threading, turning operations with static or rotating part. This Machine configuration can be up to 56 units with 3 CNC axes on three ways (vertical from the top, the bottom and radial). (Sponsored)
This machine has been designed for making complex parts in only 1 machine in super aggressive cycle time, avoiding multiple operations cell. Automatizing a complex process flow, with many machines and operators involved in only on single and compact solution.
Piccola can produce from bar stock (up to 1.26") or coil or blank (casting or forging).
Piccola is a very precise and repeatable machine thanks to a temperature control system. Gnutti develops this system for keeping thermal stability of each machine element. Through open and closed circuits, all elements are maintained at a constant temperature. Thanks to this temperature adjustment, the entire machine maintains a stable temperature independently from heat caused by machining operations and external agents. The centralized heat exchanger makes it possible to regenerate this kind of energy.
Precision Machining Technology Moving Shops Forward
New equipment and software continue to be developed to support the needs of production machine shops like yours. Here’s a sample of technology now on the market that can help you grow your operation and become more efficient.
A Different Kind of Machining Center
If one horizontal machining center is good, then three on a single platform should be better, right? That’s the thinking behind the Multicenter concept from Italian builder, Porta Solutions. It blends the volume production capabilities of rotary transfer technology with the flexibility of a machining center in a single platform.
Rotary Transfer Offers Full OD Turning Between Centers
This small-footprint trunnion rotary transfer machine includes an isolated cell to perform full OD turning between centers for improved concentricity compared to flipping parts in a station for backside turning or moving the part to another clamping position.
