Moving Vertical Turning Up
There is always room for improvement, and transitioning from vertical turning to inverted vertical turning can be one way to improve your shop’s efficiency. The benefits of inverted vertical turning include a smaller machine footprint relative to horizontal turning centers of similar capacity; multitasking capabilities; and maybe the biggest benefit—chips fall away from the spindle into a conveyor in the machine base and out of the workzone.
#basics
A traditional vertical turning lathe (VTL) includes a base-mounted spindle to which a workpiece blank is held. A gantry-mounted tool carrier brings the machining axes into the cut much like the design of a VMC. The spindle base can be as large as necessary because gravity is its natural workholder.
The VTL’s basic technology has undergone refinements through the years with the addition of milling and drilling capabilities as well as CNC servo control of the axes. But in the early 1990s, a new VTL configuration was introduced to the market: inverted vertical turning.
With the inverted spindle design, the spindle axes are mounted on a slide where the traditional tool VTL carrier was mounted. In that position, coupled with the mobility afforded by the slide mount, the spindle serves the dual purpose of loading and unloading the machine while presenting the workpiece blank to the cutting tools that are now in the position where the traditional table was, inverting the VTL 180 degrees.
According to the article “Programming Considerations for Inverted Vertical Turning,” benefits of inverted vertical turning include a smaller machine footprint relative to horizontal turning centers of similar capacity; multitasking capabilities such as hard turning and grinding, drilling, milling, hobbing and measurement all in a single part handling; and maybe the biggest benefit—chips fall away from the spindle into a conveyor in the machine base and out of the workzone.
Read “Programming Considerations for Inverted Vertical Turning,” to learn more about inverted vertical turning. Read “Adding Value, Reducing Cost,” to learn about inverted vertical turning centers finding a home in an automotive stamping house.
Get 5-Axis Machining on a 3-Axis VMC
Machine shops want and need to eliminate steps in the manufacturing process. Adding four- or five-axis capability to an existing three-axis VMC is a practical way to achieve five-sided machining using a single setup.
Selecting A VMC: Factors To Consider
A three-, four- or five-axis vertical machining center can run the gamut of capability and cost. Assessing your application requirements now and in the future can make for a much wiser machining center purchase.
