Every month, we’re putting together a Technology Showcase, highlighting some of the product information that PM received from supplier companies. For May, we focused on workholding, including a spindle designed to generate smaller, more manageable chips to improve chip flow and spindle accuracy; collet chucks and standard collets that are modified to mate exactly with unique die cast part configurations; jaws designed to bite into the workpiece, providing increased holding power during turning operations; and more as described below.
For the latest new products across the broad spectrum of precision machining, check out Production Machining’s New Products online.
Read PM’s April Technology Review.
Swiss-Type Add-On System Enables In-Line Inspection
When small part inspection and/or segregation is critical, this flexible, automated unloading and palletizing system for Swiss-type lathes can be the answer.
Targeting Spindle Alignment for High Machining Accuracy
This 5-axis laser target for spindle and axis alignment offers a fast and highly accurate way to measure spindle alignment, axis straightness and squareness on lathes, multitasking machines, machining centers and ID/OD grinding machines.
Bridging the Gap Between Traditional Single- and Multi-Spindles
This twin-spindle automatic lathe with six cross-slide mounted turrets is designed for medium-sized production runs that might not be suitable for conventional multi-spindles.
