Video Tech Brief: 3D Optical Part Measurement Explained
Oasis Inspection Systems added a rotary stage to its optical measuring units enabling them to perform automated 3D measurement of machined part features.
Part measurement can become a bottleneck, especially for high-volume production shops. Devices such as non-contact optical systems from Oasis Inspection Systems automatically measure multiple profile dimensions on small parts simultaneously and in real time with all measurements done in less than a second. In fact, the addition of a motorized rotary stage turns this 2D inspection process into a 3D process.
Inspectors can ensure that their parts are within specification limits all the way around without manually turning the part. In addition, rotating the part adds the ability to check additional features such as roundness and concentricity.
With the included software update, all of this additional data is recorded with the built-in Oasis inspection report or can be automatically imported into any statistical process control (SPC) program. In continuous mode, the part continuously rotates on the stage at a user-defined speed to enable the inspector to view the measurements and status display panel as the part turns. In fixed-duration mode, the inspector defines how many rotations the stage will make and how many times to measure the part while rotating.
Oasis Inspection Systems optical part measuring machine
  • Determine Passivation of Stainless
    Properly cleaned stainless steel is naturally protected from corrosion by a thin, passive film. But this passive layer can be removed or scratched. A passivation meter measures the surface potential under controlled conditions.
  • Why a CNC Multi-Spindle Machining Center Makes Sense for MetalQuest
    An early adopter of multitasking equipment, this Nebraska contract manufacturer has taken what it feels is the next logical step to diversify by adding a multi-spindle for greatly reduced cycle times on an existing high-volume job.
  • How to Choose and Use Styli
    The variety of probe applications on machine tools, CMMs, comparative gages and portable arms makes correct selection of styli usage essential for efficient, reliable and accurate measurement. Here are some key points that can be helpful in choosing the best measurement solution.
