Complete Grinding Solutions in Springboro, Ohio, uses its United Grinding Studer S41 universal grinding machine to perform high-speed peel grinding for components made of challenging materials. Photo Credit: PM
High-speed machining using CNC milling machines is a process in which a cutting tool takes fast, light cuts at high spindle speeds to realize higher material removal rates compared to slower hogging operations. Similarly, the goal with peel grinding is to achieve high material removal rates for cylindrical parts requiring outer diameter (OD) grinding. However, this high-speed grinding process differs from its milling counterpart in that, while the operation uses fast grinding wheel speed, it also takes relatively deep passes. It is able to do this because the grinding wheel is very thin and the grinding forces imparted into the workpiece are very low compared to plunge grinding with a wider wheel.
In fact, peel grinding operations resemble single-point turning on a lathe, as I learned during a visit to Complete Grinding Solutions in Springboro, Ohio. That’s because, similarly to a lathe tool, the grinding wheel moves in the X and Z axes to grind contours, different diameters and other features on a workpiece, the company explains. When combined with proper grinding wheel technology and high-pressure, straight-oil coolant delivery, the very high speeds enable improved material removal rates for challenging materials such as carbide, ceramic, polycrystalline diamond and even glass.
Peel grinding differs from plunge grinding with a wide, profiled wheel. As with turning using a single-point tool, peel grinding maneuvers a thin wheel to grind the profile of a part. Therefore, a single wheel can grind a variety of diameters, contours and other features. In most cases, there is no roughing pass followed by a finishing pass. Typically, one heavy cut takes care of all necessary material removal while leaving behind a quality surface finish.
This is because the face of the thin wheels has a lead angle where roughing/material removal is performed followed by a flat profile that provides a finer ground finish. Therefore, one pass of the wheel performs both roughing and finish grinding. Most wheel wear occurs at the corner where those two areas transition, meaning the wear rate is essentially the same whether shallow or deep grinding passes are made.
A small area of contact means both tangential and normal grinding forces are low. In addition, as wheel speed increases, both forces decrease exponentially. Low grinding forces mean that long, relatively small-diameter workpieces might not require a steady rest for added support during peel grinding. Plus, the heat created during peel grinding is evacuated with the chips, which prevents workpieces from burning and facilitates faster grinding speeds. Peel grinding’s reduced grinding forces mean wheels require dressing less frequently, too.
That said, proper coolant selection (straight oil is recommended) and delivery is also necessary to provide sufficient lubrication at the grinding wheel’s cutting edges. In addition, peel grinding requires coolant delivery at high pressure to ensure the coolant gets to the area of contact between the wheel and workpiece.
Should You Bring Tool Regrinding In-House?
In some situations, the potentially high investment in an in-house tool grinding process can be justified with a relatively fast ROI. (Includes video.)
Establishing an Effective Production Process for Femoral Balls
Grinding, honing and buffing can be performed on one machine to eliminate the need for these medical implant components to run across multiple pieces of equipment.
Tooth Flank Grinding Technology Minimizes EV Drive Noise
