Diamond Lapping and Lapping Plate Control
The word “diamond” brings the word “expensive” to mind. But when it comes to lapping with diamond superabrasives, start thinking “low”—as in lower slurry consumption, lower slurry cost per hour, lower sludge generation, lower cycle time, lower reject rates and fewer process steps.
Diamond lapping might be appropriate for machining/finishing operations that face challenges such as greater planar, spherical or conical surface requirements; improved sealing; improved cosmetic surfaces; planarizing joined dissimilar materials (for example, laminates, composites); surface deburring, removal of “gummy” materials; super-hard materials that are only economically processed with the use of diamond; and thinning/finishing poor aspect ratio parts.
Common industrial applications for diamond lapping include mechanical seals, seal rings, valves, stamping dies, pump bodies, slitter blades, gage blocks (“Jo-blocks”), micrometer spindles, fuel injection valves, dies/gaskets, CD molds, mirrors and micro electro-mechanical devices (MEMs). Almost any material can be lapped, including steel, stainless steel, chromium carbide, tungsten carbide, aluminum, copper, bronze, Alinco (aluminum-nickel-cobalt), ceramics, glass, sapphire and plastic.
What is Lapping?
Lapping involves a medium (superabrasive and associated paste or liquid carrier) that is applied between the workpiece surface and a lapping plate.
While some of the diamond particles become embedded in the lapping plate to perform a fine grinding action, abrasive particles in lapping may also be continuously loose and rolling “free particles” see Figure 1. Lapped surfaces do not have directional marks. The lapping process works by pushing the points of the diamond grains into the work surface to abrade microchips of material. Imagine this kneading or abrading action on the work surface being repeated millions of times over to produce effective material removal, as well as provide a simultaneous polishing action (especially when using abrasive particles as fine as 50 nm).
To gain the full benefit of the inherent strengths of diamond as an abrasive, the ideal lapping machine design features high down-pressure/down-force
(5 psi and higher), has a robust drive system to tolerate the high down-pressure used and a variable speed drive with high top-end RPM capability.
Compared with lapping with conventional abrasives such as aluminum oxide, lapping with superabrasives offers the following benefits:
• Aggressive material removal for equal or better productivity
• Uniform edge-to-edge flatness; sub-light band (11 millionths inch) results are routine; as high as 1/20 wavelength is achievable under specific conditions
• Better than sub-micron surface finish (< 0.5 Ra) is routine; sub-nanometer surface finishes are achievable
• High potential to develop a one-step lapping and polishing solution for reduced cycle times
• Reduced waste to support green initiatives
System Approach
With the need to meet objectives relating to statistical process control, six sigma, lean and green initiatives—coupled with ever-increasing cost pressure—companies need to continuously re-examine all of their machining and finishing processes. When it comes to fine grinding and lapping, best results occur by taking a systems approach that examines machine tools, abrasive powders and slurries, plates/pads and accessory options and matching them against specifications for consistent part quality, processing time, environmental requirements and overall costs.
As shown in the ceramic parts case study (see Figure 2), diamond superabrasives provided a more effective solution. It eliminated the hand-polishing step, reduced cycle time by 30 minutes, saved $14.87 per hour in slurry costs, reduced slurry waste and associated disposal costs, reduced cleaning time and reduced use of cleaning solutions. Lower-volume requirements for diamond slurry also reduced shipping and inventory costs.
Maintenance Considerations
Lapping plate maintenance with superabrasives differs from conventional lapping, which usually uses a cast iron plate. Superabrasives typically use a composite metal lapping plate made from tin (TX-10A), copper (HY Cu) or iron (X-08). After a certain period of use, the lapping plate becomes worn and requires reconditioning to re-establish plate flatness to meet end-part tolerance, as well as meet surface finish requirements. Plates also become “glazed” and no longer remove material at a consistent rate, which in turn, introduces undesired production variables.
Reconditioning a diamond lapping plate requires cutting away the top surface to restore flatness and retexturing the plate so that it can be “charged.” Charging is the process of embedding diamond abrasive into the plate (embedded or “fixed” diamonds).
Until Engis developed its FastLap Facing Device, reconditioning involved using diamond-plated conditioning rings and the experience of a highly skilled operator. While results are satisfactory, it is a demanding task, resulting in excessive machine downtime and unpredictable production losses. Optical micro-graphs and image analysis software reveal that this process imparts a random texture and an uneven “bearing ratio” (the percentage of surface area with which the workpiece will ultimately come in contact).
A facing device uses a diamond tool bit to remove the top (worn) layer of the lapping plate, machining it flat to within microns. To produce a controlled surface geometry and texture, the device then makes a second pass, which machines a groove pattern (see Figure 3) that serves as the basis for structured embedding of abrasive particles.
Controlling the groove pattern (macro texture) and lands (micro texture) of the plate surface allows for more consistency in removal rates and surface finishes. A consistent bearing ratio means consistent unit load, repeatable removal rates and excellent batch-to-batch consistency. The reduced contact area provided by a grooved plate increases the load per unit area, therefore increasing removal rates. The groove also aids in clearing away swarf.
The development of facing devices was driven by the need to increase first-pass quality and reduce scrap costs in the electronics industry (imagine the cost of scraping sapphire optical components and semiconductors), but the precision machining industry can benefit, too. If a company determines that superabrasives would add benefit to its operations, a facing device eliminates concerns about finding an operator with the skills to maintain a plate using traditional techniques, thus simplifying the integration of a diamond lapping system.
With lapping, it is important to remember that consistency is the key to success, and successful companies make every effort to control the bearing area, pressure, platen speed, charging process and dispensing of slurry. Controlling these variables leads to more uniform surface finish, stock removal rate, flatness or desired contour, part size/thickness and planarity—and customer satisfaction.
The Advantages of Turning and Grinding on One Machine Platform
Read MoreEmag Grinding Solutions Provide Precise Gear-Profile Grinding
The G 160 and G 250 gear-profile grinding machines provide short chip-to-chip times, intelligent axis concepts as well as thermal and mechanical stability.
Read MoreJunker Grinding Machines Feature Modular Design
The Platform 3 series of modular grinding machines is designed to provide increased flexibility and cost-effectiveness.
Read MoreTooth Flank Grinding Technology Minimizes EV Drive Noise
Read MoreFielding Manufacturers’ FAQs about CMMC
Here are answers to frequently asked questions we as a provider of testing, consulting, information and compliance services receive about Cybersecurity Maturity Model Certification.
Read MoreAvoid the 7 Deadly Sins of Manufacturing
