A machine tool’s control can be a barrier to reducing the machining
cycle time and improving the finish of complicated 3D molds, aerospace
parts or medical-device components. When the processor can’t keep up
with the program, the drives starve for information, slowing tool
progress, increasing cycle time and inducing inconsistent tool motion.
This causes inefficient use of the spindle, which increases benchwork
finishing time in addition to the number of trips to the tool crib to
replace worn, overloaded tooling. GBI Cincinnati and MTI Technologies
worked together on this problem and came up with a series of machine
tools called Revolution. These machines are said to combine the
quickness of modern control technology and precision in machine tool
motion to yield true constant velocity.
Savvy
manufacturing engineers and CNC programmers know that programming at a
feed rate of 100 ipm does not guarantee that the tool moves at 100 ipm.
In fact, it is almost always less than the target feed rate. The reason
for this is that the control’s ability to generate the position of the
tool in space given the part geometry, tool height offsets, tool radius
offsets, common offsets and workpiece offsets requires complicated
algorithms that must generate every point in the tool path as the tool
moves across the part. The control also must calculate approach and
escape motions as well as acceleration and deceleration.
Most
controls in use today trace their roots to architecture that is 30 or
even 40 years old, when among other things the download speed of the
RS-232 connection was a bottleneck. Controls of this type can yield
block-read speeds of up to 5,000 blocks per second. While this is
sufficient for many part programs, complicated parts can require much
more than that. When MTI’s Carlo Miceli began to work on his own
control, he started with a fresh approach to PC machine language logic
and efficient information processing. The product was a CNC control
based on modern PC hardware coupled with a new approach to toolpath
algorithms that produces a read speed of more than 50,000 blocks per
second. GBI Cincinnati
says the result is “constant velocity” machining, which yields fast,
constant feed rates. When the velocity (feed rate) is not constant,
several problems can result.
The uneven motion of the tool loads the flutes differently as the
tool passes through the part, adversely affecting accuracy and surface
finish. Inconsistent motion can also shorten tool life by not moving
the cutter fast enough to maintain minimum chip load, causing it to rub
rather than cut. Such motion can also create small breaks in the tool’s
edges, creating heat and dulling the tool. However, by using constant
velocity, the average speed of the cutter moving across the part is
more uniform and more accurate, reducing finishing time and prolonging
tool life.
On the Revolution series of machining centers,
the MTI control does not create the excessive stress sometimes
associated with high speed machining, allowing fluid tool motion for
complicated part geometries.
The MTI control can also be
retrofitted to an existing machine. The retrofit kit uses a series of
control parameters to determine the maximum allowable G-force loading
and safe operating limits. Standard kits are available now for many
Fadal machining centers, with kits for other machines to become
available in the future.
One result of the high block
processing speed is that the control-follow error is constantly
monitored and adjusted to achieve uniform tool motion and surface
integrity during program execution. The system uses more than 80 high
speed buffers to control and monitor tool motion, which can be adjusted
instantaneously if the follow error becomes excessive.
The
sum of the control quickness, drive tuning and efficient handling of
the tool path is said to yield fast and accurate program execution even
when working with complicated shapes. GBI Cincinnati plans to have
three Revolution machining systems ready by IMTS 2008. Each will offer
machine design features with MTI’s control technology to solve problems
in the moldmaking, aerospace and medical device industries.
