Automating cutting fluid management can free shopfloor employees from what would otherwise be labor-intensive maintenance tasks. (Photo credits: Master Fluid Solutions)
When it comes to manufacturing automation, most people immediately think of robots or perhaps complex artificial intelligence systems. While it’s true the industry is becoming increasingly technology driven, business owners don’t need to completely overhaul their operations to keep up. Leaders can implement automation on a process-by-process basis, including cutting fluid management.
Keeping cutting fluid free of tramp oil, bacteria and other contaminants is a proven way to extend both coolant and tool life, reduce operating costs and even improve a machine shop’s environment. However, it can also be labor intensive and require dedication, which makes cutting fluid management a good candidate for new equipment investments.
Cutting fluid management can transform an operation and automation can amplify its benefits. Automation removes many manual touchpoints of cutting fluid management so tasks are performed more efficiently and consistently.
One example is sensors in the machine sump that can detect concentration, reducing the need for manual fluid checks. Filling systems can also automatically add more coolant to the mix without oversight. Equipment can automatically handle almost every aspect of sump cleanouts and fluid recycling as well.
More streamlined maintenance processes translate to less machine downtime, too. Because many systems can manage cutting fluid quality on an ongoing basis, there’s less need for actual shutdowns and cleanouts. When a full shutdown is necessary, fluid management equipment can handle maintenance processes faster and more effectively than manual effort, so operations face less disruption.
Shopfloor employees can better use their time on other revenue-generating activities rather than rigorous maintenance processes.
In addition, higher machine uptime translates to higher overall productivity for an operation since throughput remains steady. Shopfloor employees can then use their time on other revenue-generating activities, rather than rigorous maintenance processes. Not only are existing production orders completed faster, but shops also have added bandwidth to take on additional jobs.
Investing in Cutting Fluid Management
Even though cutting fluid management equipment and automation can be easier to implement than other forms of manufacturing automation solutions, it’s important to take the transformation slowly, going step by step. Here’s a suggested framework to follow:
- Start with fluid management basics. The first tools a machine shop should invest in for streamlined cutting fluid management is an automatic refractometer and a solution to mix coolant, such as a proportioner. These two devices are required to maintain proper concentration in the sump, which is the basis for all cutting fluid management practices. Implementing these two solutions can help significantly cut operating costs when it comes to fluid spending.
- Prioritize cleaning systems. After purchasing basic equipment, the next phase of investment is equipment that actually cleans cutting fluid. Tramp oil removal systems such as skimming belts and coalescers can collect tramp oil from the sump on an ongoing basis and help prevent bacterial growth without extra effort. Coolant cleaning systems are an important step to extending fluid life, reducing costs even more.
- Invest more as needed. When an operation reaches higher levels of metalworking fluid spend each year, it makes more sense from an ROI perspective to invest in more advanced fluid management equipment. At this point, consider automated fill systems to improve efficiency as well as fluid recycling systems that eliminate virtually all contaminants from coolant for maximum performance and minimized waste. Extending coolant life and reducing waste costs will accelerate ROI and set your company up for even more future investments.
This coolant recycling system uses advanced coalescing and filtration technologies to assist in the removal of tramp oils, solids and bacteria in the coolant.
Manufacturing automation is the future of the machining industry, but it’s important for shop managers to take care of foundational investments so their operation remains on stable ground. Just as proper cutting fluid management is the basis of a cost-effective machine shop, cutting fluid management equipment and automation should be the basis of a future-proof machining business.
About the Author
Justin Geach is global director of marketing for Master Fluid Solutions.
Read MoreInside the Premium Machine Shop Making Fasteners
Read MoreUnattended Production Takes More Than the Most Capable CNC Machine
How Well do You Know Granite Surface Plates?
Read MoreShop and School Symbiosis
PMPA member Clippard Instrument Laboratory has been working with Butler Tech for over 45 years and the benefits keep growing.
