Every month, we’re putting together a Technology Showcase to highlight new product information that PM has received from supplier companies. For the latest new products across the broad spectrum of precision machining, check out Production Machining’s New Products online.
If you would like to learn more about the latest news, product technology and operational best practices in the precision machining industry, consider subscribing to Production Machining’s free monthly print magazine.
Read PM’s Precision Machining Technology Review September 2024.
Ceratizit Milling Tool Enables Dynamic Positioning
Source: Ceratizit USA Inc.
Ceratizit USA’s FreeTurn tool features a slim, axial structure that enables users to benefit from 360 degrees of freedom in the axis without the risk of collision.
The dynamic positioning optimizes chip breakage and improves component quality by changing the position during the process. Undercuts or contours, which currently require an additional tool, can be produced. With FreeTurn, shops can rough, finish, contour turn, face or longitudinal turn with the same tool.
Kennametal Turning Tools Improve Chip Evaluation
Kennametal Inc.’s TopSwiss turning inserts are designed for Swiss-type small parts machining. TopSwiss turning inserts are engineered for low-feed, high depth-of-cut (DOC) applications across industries including medical, aerospace and defense, general engineering and transportation.
The turning portfolio features:
- Four carbide grades, one cermet grade and seven geometries.
- Straight and curved cutting edges for stable cuts and smooth chip flow in low feed, high DOC applications.
- Polished finishing geometries for increased welding resistance and improved surface finishing.
- Medium and finishing wiper geometries for increased feed rates and superior surface quality.
- Several geometries with high chipbreaker walls and large pockets for better chip evacuation.
Mate Workholding System Maximizes Repeatability
Source: Mate Precision Technologies
Mate Precision Technologies has introduced a series of enhancements to its 52/96 zero-point workholding system. The enhancements include:
- Machinable Hard Jaws: These enable users to create custom profiles from blank jaws. Customers can request Mate to customize the hard jaws with delivery usually in 10 days or less, or they can order blank profiles to customize in-house.
- DynoGrip ER Collet Chucks: These collet chucks provide an easy and reliable solution for holding round parts during milling operations. The industry-standard ER32 and ER40 collets accommodate diameters from 2-32 mm (0.08"-1.26").
- DynoGrip Direct Mount Vise: A wider body provides additional flexibility and allows for direct bolting to a machine bed, pallet or other fixture. It includes two 10-mm counterbores on center, 100 mm apart for direct mounting.
- DynoMount Lower Profile Pyramid: This three-sided pyramid is designed for more compact machining spaces.
Horn Milling Tool Features Modular Design for Quick Changeovers
Horn’s DG modular interchangeable head milling system is said to optimize the interface between the cutting head and shank for greater versatility, stability and higher changeover precision. According to Horn, this is made possible by the solid carbide monoblock design of the replaceable head. It means that the interface and the desired cutting-edge shape are precision ground from a carbide blank. The system achieves high precision through a guide pin, a precision trapezoidal thread and a taper/flat contact. The changeover accuracy is in the µ range. This reduces setup times and cuts production costs. The modular design enables quick changeover to a different cutting insert and the use of customized special solutions.
Mazak Smart Device Enhances Machine Connectivity, Security
Source: Mazak North America
Mazak’s SmartBox 2.0 is designed to enhance and secure machine connectivity. Building on the company’s original SmartBox digital integration technology, Mazak has developed this latest version with several features and enhanced connectivity.
The SmartBox 2.0 introduces message queuing telemetry transport (MQTT) and open process communications (OPC) protocols, which improve data exchange and interoperability with a broad range of industrial systems. This version also includes an industrial-grade edge computer PC as standard, advancing its capabilities for machine monitoring and analysis while incorporating advanced cybersecurity protection.
