Miniature Inserts Reduce Tooling Change Frequency
Iscar’s Nanmill and Sumochan tooling lines simplify sharpening processes and reduce full tool change-outs.
Milling and drilling operations that require tooling under 10 mm in diameter have historically not had many options beyond solid carbide or high speed steel tools. Iscar is changing that story with its miniature indexable Nanmill shoulder-cutting tooling, as well as its Sumocham line of hole-making tooling with interchangeable solid carbide heads. These tooling lines, both of which are on display at Iscar’s booth, reduce the complexity of setting up automated production runs in a lights-out setting.
In production setting, small end mills and drills made of a solid material tend to be sharpened or replaced at short intervals. The frequency of these change-outs are typically out of sync with the larger tooling that commonly leverages indexable inserts. Iscar’s 4-mm indexable Nanmill shoulder-cutting inserts provide the opportunity to restore a cutting edge without fully removing the tool, eliminating costly, time-consuming tooling changes.
The solid carbide heads found on Iscar’s Sumocham hole-making tooling offer similar advantages: faster changes on tools that are typically made from solid material. The ability to replace the drill head eliminates the need to sharpen or replace the entire tool. By restoring a factory edge without entirely replacing the tool, there is no need to zero out a freshly sharpened tool.
Iscar’s Nanmill inserts combine a small size, indexability and a small-diameter multi-toothed end mill. The company says the triangular insert’s three cutting edges are well-suited for 90º shoulder milling and reduce diameter size to 8 mm. Photo Credit: Iscar
VR at UR: See Cobots in Another Dimension
Universal Robots’ expansive two-story IMTS booth in the North Hall features a VR headset interface that will give you exact tool and joint positions in real time as you manipulate the arm with the virtual gripper.
See Chip Control and Chipless Cutting at Marubeni Citizen-Cincom
Visit Marubeni Citizen Cincom’s booth to see how the new Low Frequency Vibration (LFV) cutting technology deals with the problem of chip accumulation.
Swiss Machining Demo Shows Off Carbide Cutting Tool Lines
Pilot Precision, Palbit’s exclusive U.S. distributor, showcases Palbit’s cutting tools as well as its own broaching and drilling products.
