Every month, we’re putting together a Technology Showcase, highlighting some of the product information that PM received from supplier companies. For August, we’re focusing on tooling.
For the latest new products across the broad spectrum of precision machining, check out Production Machining’s New Products online.
Read PM’s Precision Machining Technology Review July 2023: Data-Driven Manufacturing.
Diatool Top Speed Ring Provides Fast, Precise Reaming
Photo Credit: Monaghan Tooling Group
Monaghan Tooling Group’s Diatool Top Speed Ring (TSR) modular reaming system is said to achieve up to 70% faster feed rates with out-of-the-box functionality. With up to four additional cutting blades, this design enables faster machining as well as increased tool life to achieve unrivaled performance and cost-efficiency.
The Diatool TSR covers a diameter range of 50.000 mm to 225.000 mm (1.9685" to 8.8583"), making it an optimal solution for a diverse range of precision reaming applications. It is well suited for long production runs of large diameter bores, precision reaming of heavy equipment components or any application requiring precise and repeatable bore sizes.
Big Daishowa Toolholder Increases Precision for Lathes
Photo Credit: Big Daishowa
Big Daishowa has introduced the C3 program, an expansion of the Big Capto toolholder line, designed to increase efficiency and precision for small lathes.
The C3 series of Mega New Baby chucks has a clamping range of .010-.630" with a maximum rpm of 30,000. According to the company, these make excellent choices for drills, reamers, taps and finishing end mills. Ultra-slim and strong, they provide reliable gripping for even the smallest workpieces.
Tungaloy-NTK PCD Grade Offers Optimal Dimensional Accuracy
Photo Credit: Tungaloy-NTK America Inc.
Tungaloy-NTK America Inc. has unveiled its latest development of a polycrystalline diamond (PCD) grade that is designed to provide exceptional wear resistance in hard, non-ferrous metals. DX200 is made of 100% pure diamond using no binder to make the bond between the diamond grains.
Boasting the highest hardness of all Tungaloy’s PCD-grade lines, DX200 is best suited for finish machining of carbide and hard, brittle materials, primarily tungsten carbide, cemented carbide and metal matrix composites (MMCs). In addition, the PCD cutting edge features an excellent edge-line security and sharpness, permitting the insert to achieve optimized dimensional accuracy over extended periods of time.
Kennametal Drill Fix Pro Offers Extended Application Range
Kennametal has upgraded its Drill Fix indexable drilling platform with Drill Fix PRO, offering customers a cost-effective solution for a wide variety of drilling operations.
Designed for extended tool life and smooth drilling at high metal removal rates, Drill Fix Pro has outboard inserts that feature a wiper geometry for smoother surface finishes and larger coolant channels for high-volume flow. Other platform advancements include the versatility of the four-time indexable cutting edges that offers an extended application range.
Drill Fix PRO is applicable for machining centers, drilling machines and lathes. While on lathe machines, it can also be used as a boring bar, making use of the X-offset feature in horizontal cutting.
Shrink-Fit System Offers OneTouch Displays, Rapid Tool Cooling
The Diebold/Accutek US1100 Series of shrink-fit machines combine Accutek’s shrink-fit technology with the Diebold brand of shrink-fit machines and feature the latest OneTouch display and Pyrometer Coil technology.
The OneTouch Display is an operating mode that works in conjunction with the machine’s TempControl (Pyrometer Control) safety function. This feature is designed to eliminate operator errors and the overheating of shrink holders. Also, it means that no selection of parameters are required. Users can set the shrink process with just one touch. The system provides a graphical visualization of shrinking process and hands-free operation with an optional foot pedal. It is also IoT 4.0 ready with Ethernet and data exchange.
Landscape Source: Kennametal
Production Machining’s January 2024 technology showcase includes some of the latest technology from Monaghan Tooling Group, Okuma America, Tungaloy, Cortec Corp., Fixtureworks and T.J Davies Co. Inc.
This cell is able to perform joining, preheating and welding operations for rotor shafts used in electric vehicles.
Throughout April, our discussions spanned various technologies, yet a common thread emerged: workforce development. Take a look at the most-viewed articles in April, based on Google Analytics.
