Quick Setup Multi-Spindle Machines Offer Production Flexibility, Speed
Gnutti explains how its models of multi-spindle machines can work with a variety of material types while offering faster setups and cycle times compared to conventional multi-spindle models.
In this Digital Demo, Gnutti explains three primary advantages of its models compared to conventional multi-spindle designs. These include:
Features enabling quicker setups and more flexibility:
  • Bar feeder — For different diameters, the only adjustments needed are the center of the bar and the bar pusher (there are no channels).
  • Collets — The  machines can be fitted with self-centering jaws (quick-change) or standard quick-change collets from Hainbuch.
  • Tools — Spindle units have standard ISO or HSK tapers, so all the tools are presettable outside the machine. Capto turning tools are also available.
  • Full CNC axes — All the axes are FANUC CNC, so all are programmable and adjustable with offsets.
  • Standard 2-inch bar capacity — Machines can be configured to handle bigger parts that a conventional multi-spindle can’t handle.
Faster cycle time:
  • It is possible to better split the cycle time between machining stations and not worry about backworking operations by using as many as nine stations for each side of a part.
  • There is no bar spinning, so machines can achieve higher rpm even with bigger parts (or shaped bars) because there aren’t multiple bars spinning simultaneously.
Coolant options:
  • Machines can use oil or water-soluble coolants depending on the application.
For more information on this and other Gnutti products, visit Gnutti.com and follow them online on Instagram, Facebook, Twitter, YouTube, and LinkedIn.
Bar Turning 50
Photo Credit: Gnutti
  • Lean Transfer Machine PICCOLA
    PICCOLA CNC Lean transfer machine, extremely flexible and productive, able to perform boring, milling, threading, turning operations with static or rotating part. This Machine configuration can be up to 56 units with 3 CNC axes on three ways (vertical from the top, the bottom and radial). (Sponsored)
