When it comes to the deployment of industrial robots, the auto industry continues to dominate new orders. While one might imagine that the number that is already installed in factories is such that there would be a decline in orders, that is far from being the case. For example, looking at orders for the first half of 2019 (full year numbers aren’t available at the time of this writing, so even if there were to be a substantial decrease in the second half, as you’ll see in a moment, it would still be a big number), the order growth year-over-year, according to the Robotic Industries Association, was 83% for automotive OEMs. The semiconductor & electronics/photonics industry came in second—just 12%.
Evidently the developments that are being made by the robot companies are such that they are worth the investment to improve overall productivity.
Welding & Handling
If there is any application that seems to be the most descriptive of robots in automotive it is welding. Who hasn’t seen the picture—even in consumer publications—of bodies-in-white on the line with robot arms and showers of sparks from spot welding guns?
And another big application in auto (as well as in other industries) is handling. According to the International Federation of Robotics (IFR), in 2018 China led the world in the installation of new robots (154,000); Japan was second with a comparatively mere 55,200, and the U.S. third at 40,400 installations. The IFR figures show that in China handling is the #1 robotic application, followed by welding. So clearly there is a lot of attention being paid to those two applications by companies that are interested in getting their equipment into manufacturing operations anywhere in the world.
Hollow Arms
Which brings us to the six-axis R-2000iD/210FH robot from FANUC America. The robot has a 210-kg payload and a 2,605-mm reach, so it is a unit that is engineered for both spot welding and material handling applications.
The robot has a hollow-arm design, which means that there is full internal J1-J6 cabling. By running the cables through the arm rather than exterior to the arm, there is better cable management and the robot can be deployed in tight spaces.
Quick Moves
For example, there is the SP110 robot, which has a maximum payload of 110 kg, a horizontal reach of 2,044 mm and a vertical reach of 3,367 mm. As regards the speed for each of the axes:
- S = 140°/sec
- L = 115°/sec
- U = 161°/sec
- R = 225°/sec
- B = 200°/sec
- T = 315°/sec
Other robots in this new series of spot welding units are the SP180H (180-kg payload; horizontal reach of 2,702 mm; vertical reach of 3,393 mm); SP180H-110 (11-kg payload; horizontal reach of 2,702 mm; vertical reach of 3,393 mm); SP225H (225-kg payload; 2,702 mm horizontal reach; 3,393-mm vertical reach). Again, like the SP110, they are designed for fast moves through space. All of the robots are controlled by the YRC1000 controller; a single cable is all that is required to connect the manipulator to the controller.
A Cobot That Welds
Another burgeoning category of robot is the collaborative robot (a.k.a., “cobot”) robots that can work with humans as sensors cause the arms to immediately shut down in the event of contact with the coworker), and FANUC has developed arc welding specific cobots. There is the six-axis CR-15iA for ARC, which has a 15-kg payload capacity and 1,441-mm reach and the smaller CR-7iA/L for ARC (there are also versions of both of these cobots that are without the “for ARC,” meaning they can be used for non-welding applications, too), which has a 7-kg payload and 911-mm reach.
The CRX-10iA cobot from FANUC is the company’s latest generation of robots for collaborative work with humans. (Image: FANUC America)
And while on the subject of cobots, FANUC introduced in December 2019 the CRX series of cobots, the CRX-10iA and the CRX-10iA/L, both providing a 10-kg payload capacity but the former a reach of 1,249-mm and the latter a longer reach, 1,418 mm. The arms have a swing motion such that accessing parts that are located behind the robot is simple to accomplish. Both cobots use the FANUC R-30iB Mini Plus Controller; programming is a matter of lead-through programming (teach the cobot by moving it to the positions it will need for the application).
The Many Sides of Workholding
Choosing an Automatic Bar Feeder
The bar feeder is the most common form of automation for turning operations. Selecting the right one requires consideration of the applications for which it will be used.
