Photochemical Etching Explained
This subtractive metal fabrication process is an alternative to traditional methods which enables designers to create thin metal parts with intricate shapes to micron-level precision without leaving behind burrs.
Medical applications are well suited for fabrication via photochemical etching (PCE). Source (all images): Micrometal
The photo-chemical etching (PCE) process offered from companies such as Micrometal, headquartered in Müllheim, Germany, starts with the application of a light-sensitive resist to a metal surface. This metal sheet is then exposed to ultraviolet light, imprinting a precise design based on a photomask. The exposed areas, now vulnerable to the etching chemicals, undergo a controlled removal process to precisely strip away unwanted material. This method contrasts with traditional fabrication techniques such as machining, stamping and laser cutting, which can compromise the metal’s integrity through mechanical stress or heat distortion.
PCE’s precision lies in its ability to produce extremely fine features down to micron dimensions. This is particularly advantageous for complex designs in which traditional methods falter due to their mechanical or thermal limitations. Additionally, PCE enables the production of burr-free components, a critical requirement in many high-precision applications. The process’s ability to maintain consistency across large production runs further elevates its appeal in industries where uniformity is paramount.
Precision, Tolerances
The PCE technique is especially adept at producing components with intricate details, fine lines and close pitch patterns, which are essential in miniaturized electronic devices and delicate mechanical assemblies. The accuracy of PCE is not just in the dimensions it can achieve, but also in its ability to maintain these tolerances consistently across production batches. This level of consistency is invaluable in industries such as aerospace and medical whereby even the slightest variance can lead to significant performance issues or safety concerns.
One of the most significant advantages of PCE is its material-agnostic nature. The process can be applied to a wide range of metals and alloys, including those that are traditionally challenging to machine, such as titanium, nickel alloys and stainless steel. Moreover, PCE is known for its ability to maintain the intrinsic properties of the metal, such as hardness and grain structure, which can be altered or degraded in other fabrication processes.
The non-contact nature of PCE ensures that the structural integrity and surface finish of the metal are preserved. This aspect is crucial when working with delicate materials or when the end application demands a high degree of material purity and integrity. For instance, in the semiconductor industry, even the slightest imperfection or material stress can lead to significant performance degradation. PCE addresses these challenges effectively, making it well suited for producing high-precision electronic components.
For its PCE offerings, Micrometal has integrated technologies such as glass tooling, liquid resist and a continuous process flow. The company says these advancements have not only enhance the precision and efficiency of PCE but also open new possibilities in various high-tech industries.
As compared to traditional tooling methods, the use of glass as a tooling material is said to ensure a high degree of transparency and alignment capabilities, essential for intricate designs. This also results in high consistency across large production runs.
PCE can be applied to a range of medical alloys such as titanium and nitinol. This is sometimes not possible with conventional metal processing technologies.
In addition, liquid resist can be precisely applied in varying thicknesses, enabling greater flexibility and control over the etching process versus dry-film resists. This adaptability is crucial when working with complex or uneven surfaces, ensuring uniform coverage and consistent etching across the entire component. Micrometal’s liquid resist is formulated to offer finer resolution, too. This means it can accurately define smaller features and finer lines, essential for modern microcomponents used in industries like semiconductor manufacturing and precision engineering. The use of liquid resist also contributes to the overall efficiency of the process, reducing waste and improving the turnaround time for high-volume production runs.
But perhaps the most significant advancement introduced by Micrometal is its continuous PCE process. Traditional PCE processes are typically batch-oriented, which can be time-consuming and less efficient for large-scale production. Micrometal, however, has developed a continuous process flow that significantly streamlines production, enabling the handling of large volumes while maintaining high precision and quality. This continuous process involves a systematic progression of the metal sheets through various stages of the PCE process without interruption. From cleaning, coating, exposure and development to etching and stripping, each step is said to be seamlessly integrated, reducing manual handling and the potential for errors. This innovation not only accelerates production times but also ensures a consistent quality that is crucial for industries requiring high precision and reliability.
Industry Applications
The medical sector can benefit from PCE particularly in the manufacturing of surgical instruments, implants and components for medical devices, which must be burr-free. PCE is well suited for this sector due to its ability to produce biocompatible and sterilizable parts with complex geometries, critical for patient safety and device efficacy. The noncontact nature of the etching process ensures material integrity, a vital consideration in medical applications.
Examples of medical components produced via PCE include micro filters, micro mesh, blades, needles, scalpels, stents and more.
PCE is also used in precision engineering and electronics industries in which require meticulous detailing and exact tolerances. One example is complex, multi-layered parts essential for electronic devices such as PCBs, shielding components and connectors. The technology allows for the production of extremely thin and detailed metal parts, essential for the miniaturization trend in electronics.
PCE is increasingly being adopted in the renewable energy sector, too, particularly in solar and wind energy applications. Components such as connector tabs and busbars for solar panels are well suited for production through PCE.
In aerospace and automotive industries, PCE is used to fabricate lightweight, high-strength components capable of withstanding extreme environmental conditions while maintaining structural integrity and delivering requisite safety and performance.
How Small Machine Shops Can Fight Supply Chain Problems
Supply chain disruptions are still presenting challenges in manufacturing. This article examines the effects on aerospace, automotive and medical industries. It also covers ways that machine shops can be successful securing work despite the challenges created by the supply chain.
Read MoreSome Assembly IS Required
This Colorado manufacturer added a separate facility dedicated to customer assembly work and inventory management to produce subassemblies and completed products primarily for medical customers.
