It’s time to bring together the precision machining industry at the Precision Machining Technology Show (PMTS) 2023 set for April 18-20, 2023, in Cleveland, Ohio, at the Huntington Convention Center. It’s a great time to consider planning and investing for possible updates in your company’s technology, automation and software to make your business more efficient and productive. PMTS brings a broad range of technologies together all in one place to make your research time more effective.
Production Machining wants to help kick off your research with a series of PMTS Product Previews. In this group, we’re taking a look at Parts Cleaning, including a vacuum degreasing machine that uses solvents to remove contaminants from manufactured parts without the use of water or scrubbing; a parts washing system that reduces floor space requirements, and provides optimized cleaning and drying performance; a sandblasting systems that can deburr, texture and clean small, intricate parts; and more.
Before you go to the show, don’t miss PMTS show highlights in Derek Korn’s PMTS feature article and look for more PMTS Product Previews each week until the show! And don’t forget to register for the show.
For all the latest PMTS product highlights, please visit our extensive PMTS Preview Section which includes new PMTS products posted every weekday up through the show’s opening day.
Photo Credit: Alliance Manufacturing Inc.
Alliance Manufacturing Inc., the U.S. distributor for Italian-based manufacturer ILSA-MC Srl, offers enclosed vacuum degreasing machines designed for precision and critical parts cleaning applications. Vacuum degreasing is said to be an environmentally conscious alternative to traditional open-top vapor degreasing equipment. The process uses solvents to remove contaminants from manufactured parts without the use of water or scrubbing.
Photo Credit: Cleaning Technologies Group
Cleaning Technologies Group (CTG) introduces its Ransohoff LeanVeyor parts washing system, which is engineered for lean manufacturing while reducing floor space requirements and providing optimized cleaning and drying performance. All stages of the machine are insulated and compartmentalized with individually adjustable exhaust dampers, reducing system heat loss. According to CTG, the entire unit has been engineered and manufactured from the ground up to be flexible, durable, simple to operate and easy to maintain.
The microscale, consistent feed and pinpoint accuracy of Comco’s MicroBlasting sandblasting systems is well suited for deburring intricate geometries, texturing to a sharp delineation and removing thin coatings and films — all without causing dimensional changes to the underlying part. MicroBlasting (sandblasting on a microscale) uses small nozzles and a mixture of compressed dry air and abrasive to alter surface finishes and remove unwanted material.
Cool Clean’s Omega 1500 CO2 spray cleaning module is a powerful, but portable CO2 cleaning devise. This tabletop cleaning module delivers a precisely controlled stream of solid CO2 particles at high velocities to the designated part or surface. By selecting the appropriate nozzles, the device is capable of cleaning dust, debris and light oils from plastic, metal or glass parts, as well as laser-weld soot and solder flux removal.
Firbimatic’s Multisolvent 100 vacuum vapor degreaser is the flagship Firbimatic cleaning system for precision parts. With applications in the most demanding industrial sectors, the machine is especially useful for cleaning parts in the turning, precision mechanics, medical and aerospace industries. It works using modified alcohols and isoparaffinic hydrocarbon solvents in class A III.
Photo Credit: National Machine Products
National Machine Products (NMP) is a manufacturer focused on environmentally conscious products designed to help prepare and sustain manufacturers for the upcoming environmental regulations in North America. Its newest line of parts washers include ITF Parts Washing Equipment. These parts washers from Europe (both modified alcohol or hydrocarbon-based and aqueous) are said to exceed EPA regulations that will be enforced over the next several years against solvent-based, open-top parts washing systems. According to NMP, these units are proven in Europe, where regulations are in place, and provide customers clean and dry parts with no residual solvents.
Parker’s SmogHog mist and fume extractor machines are designed to protect employees, improve plant performance and help shops remain compliant with regulations. Parker’s product range includes electrostatic precipitators (ESPs) and mist-collection technology featuring the company’s Peach Saturated Depth Coalescing technology. Parker says it prioritizes matching the solution to each user’s unique application, as different processes and fluids create a variety of contaminants and challenges.
Photo Credit: Sita Process Solutions
Sita Process Solutions’ CleanoSpector is a mobile, robust handheld measuring device used for contact-free detection of residual contamination on parts. The company says the device is well suited for cleanliness inspection of parts to assure product quality as well as prior to follow-up processes, including gluing, painting, coating, welding, hardening and bonding. Unwanted, filmic contamination — such as oils, greases, cooling lubricants and release agents — are measured by determining the fluorescence intensity.
Landscape Source: Cool Clean
Thermal dynamics is important for assisting in the cleaning of a part. Adding heat or energy influences the cleaning process through its impact on chemistry, the water within the washer and its effect on drying.
Ultrasonic cleaning technology is explained here as well as how to choose a type of ultrasonic machine for an application, the kind of detergent to use, and the advantages of using this parts cleaning method.
The aim is to assess and compare the technical cleanliness of parts produced by different manufacturers or at different locations.
