A Standard Approach to Classifying Burrs
Variations in the definition of a burr created problems for shops trying to provide deburring solutions and for customers trying to figure out what solutions to look for.
What is a burr and how is a burr defined? An unclear definition of burrs was a problem manufacturing faced for many years. Every manufacturer and industry segment defined a burr differently. These variations created problems for shops trying to provide deburring solutions and for customers trying to figure out what solutions to look for.
How can there be a standard solution to a non-standard problem? The answer came in the development of a burr standard that was easy to understand and apply in the field. A team of engineers began working with manufacturing and distribution channels to develop such a standard for classifying burrs.
By looking at typical burrs on various materials and documenting the similarities and differences of each, the team identified five types of burrs. The characteristics of each type where defined and documented, and five standard burr classes were developed. This standard was quickly adopted by manufacturing companies and embraced by distribution channels.
Five Burr Classes
Five standard burr classes were developed. Burrs can form on all types of materials, including steel, aluminum, ductile iron and titanium.
Class 1 burrs are known as “micro burrs.” These burrs can only be seen with magnification and look like sharp edges to the naked eye.
Class 2 burrs are also small burrs, sometimes called “feather burrs.” These burrs are able to be seen without magnification and can sometimes be scratched off of an edge using a fingernail.
Burrs on steel and aluminum typically are classified as Class 1 or Class 2 and can be removed with standard silicon carbide advanced technology brushing (ATB) brushes.
Class 3 burrs are well attached burrs that are small in nature, but require significant, mechanical finishing force in order to be removed.
Class 4 burrs are well attached burrs that are large in nature, have significant route thickness and have a larger and stronger attachment point than Class 3 burrs.
Class 3 and 4 burrs require a more aggressive deburring product. Some success can be achieved with short-trim wheel brushes. Adding bridles to disc brushes also helps control flare and shortens the trim of the brush to make it more aggressive in steel applications. However, tackling well attached burrs on exotic materials such as hardened steel, Inconel, Hastalloy, stainless steel and titanium requires a solution such as ceramic grit with a sharp, jagged grain that provides a deeper cut and removes material faster. Class 3 and 4 burrs require finishing products that can stand up to the job and help shorten cycle times as well.
Class 5 burrs are commonly known as “extruded burrs” and are not actually burrs, but rather a deformation of extruded material caused by drilling. These deformations typically indicate a problem within a process, whether it is too high of speed in drilling or in material feed. They appear as very large burrs that extrude from the base material. The extruded or displaced material requires preconditioning with a chamfer or carbide cutter to remove the material. Preconditioning will leave the residual burr that is removed with brushing.
Two Questions
With an industry standard now in place, application engineers can simply ask two questions to get an idea of the manufacturer’s needs: What material is the manufacturer working with? What burr class needs to be removed? With answers to these questions, appropriate solutions can quickly be found. In addition to establishment of the burr classification system, other finishing concerns related to deburring include integration with automation, longer product life, aggressive/compliant brushes and deburring without changing surface finishes.
Integrating Automation
Growth in automation in general has been a trend in manufacturing and finishing for quite some time, but it is becoming more amplified as robotic applications and automated processes are being used more frequently. Automation provides accuracy and repeatable quality, day in and day out, and helps to attain tighter tolerances and higher production demands.
Finishing products can be integrated into robotic cells that mimic the movement of the human hand. CNC machines and custom deburring machines are also necessary. These needs not only impact brush design, but also the mounting capabilities of standard and customized machines.
In-machine deburring has become a new standard in the aerospace industry. Aerospace manufacturing is adopting the automotive production style and is doing away with hand deburring. New aerospace standards are creating the need for much higher precision in deburring, tighter tolerances and exact production quantities. Automated processes are being put in place to keep manufacturing in-house and maintain tighter process control.
Product design flexibility can aid in automated finishing with the ability to add flow-through coolant. Coolant provides an ideal working environment for advanced brush products and also offers many benefits for the manufacturer. Coolant keeps the nylon filament rigid for consistent finishing and aids in achieving a finer surface finish. Coolant also lowers the risk of warping and distorting parts, especially in applications where smaller or thinner parts are being processed.
Longer Product Life
Brushing is now mainstream in many applications, and users are seeking products that offer a long service life. Tough and durable finishing solutions are a necessity, so more brush suppliers are developing advanced technology lines that feature tougher nylon filaments that are not susceptible to premature fracture and that hold their grain longer, resulting in longer filament life and overall brush life.
Product life directly impacts the user’s bottom line. When looking for a deburring solution, manufacturers should not necessarily seek out the least expensive product, but one that will provide the best value, including a long service life. The ideal deburring solution will shorten cycle times and provide a long brush life.
Aggressive/Compliant Brushes
Manufacturers today are pushing their tooling harder and using in-machine deburring rather than secondary machines to precondition larger burrs on materials such as ductile iron and compact graphite iron. In response, most brush suppliers have developed products that are both aggressive and compliant. Newer filaments can do what the regular rectangular filaments cannot: They conform to a complex shape. These new brush lines include products that work well for removing large burrs on Inconel and other high nickel materials typically found in the aerospace industry.
Maintaining Rough Surfaces
Certain industries actually run into problems with surface finishes being too smooth after deburring with an advanced technology brush. For example, in the automotive industry, if the surface of some finished parts is too smooth, gaskets will not seal properly, which translates into a part that will not perform correctly. Certain parts need to have the same surface roughness (or perhaps even a rougher surface) after burrs are removed as before. Stainless steel wire disc brushes are ideal for deburring in these applications because they remove the burrs, yet maintain or roughen the deburred surface.
In order to help finishers receive the best overall value, brush makers and products finishing solution providers must be responsive to the customer’s needs and set standards for finishing products that help reduce cycle times, provide an excellent return on investment and cut consumable costs.
Micro Deburring Gets Hot
“Micro deburring,” a name commonly used to describe the deburring of tiny small parts, is often considered more of an art than a science. Although this is true to some extent, deburring micro parts does not always have to require hand manicuring parts with a scalpel under 10× to 20× magnification.
