Craftsman Cribsheet No. 135: ISO Material Groups: Stainless Steel
How to interpret the machinability of various forms of stainless steel.
The letter “M” is for all stainless steels in the ISO material group categories. Most manufacturers break it down into three subgroups. I have made it into five subgroups because of the tendency to put martensitic, ferritic, and precipitation hardening stainless steel into the P (steel) categories.
Stainless steels require sharp tools and low to no dwell times. Stainless steel especially in the higher nickel alloys work hardens readily. Spending too long in the cut or pushing too much with tools with low to no rake angle can cause work hardening.
The material listings are not exhaustive but examples of materials found in that sub-group to provide context of what materials fit into that group.
Find a grade-specific reference in a reference manual to get surface feet per minute (SFM) with high-speed steel (HSS). Multiply the HSS number by 2-2.5 and it will provide a reference point for what SFM you should use with the carbide. The SFM guidelines given based on material groups above can vary greatly, which can be seen in the machinability range.
About the Author
David Wynn
Keeping It In The Family — Succession Tips From Those Who Lived It | Part 1
PMPA members share some tips to avoid getting burned when passing the business torch from one family member to another.
‘Can You Hold This Tolerance?’ Is Not An Engineering Question
