Addition to Toolholder Line
Groove n’ Turn toolholders offer a new holder available in 1/2", 5/8", 3/4" and 1" diameters. It has a 1. 250" minimum bore and holds inserts with cutting depths to 0.
Groove n’ Turn toolholders offer a new holder available in 1/2", 5/8", 3/4" and 1" diameters. It has a 1.250" minimum bore and holds inserts with cutting depths to 0.500". Toolholders can be used on conventional, Swiss and CNC machines for ID threading inserts and grooving inserts in sizes from 0.004" to 0.155". Inserts are available in three grades of material: D2 for steels, D5 for nonferrous and HSS. TiN, TiCN, TiAlN are available. A full selection of radius and special configurations are also available.
Seco Tooling Lineup Promotes Optimized Part Processing
The company’s expanded tooling lineup is aimed at applications ranging from general ISO turning to high-volume hard turning and deep-hole drilling.
PSZ Turn Modular Quick-Change System for Swiss Lathes
Sumitomo’s PSZ Turn system provides good ergonomics and efficiency by offering a fast, reliable process and convenient cassette changes.
Monaghan Compensation Chucks Convert Standard ER Holders
Diatool ER Hydraulic Compensation Chucks enable users to convert standard ER holders to a repeatable, steerable hydraulic chuck for more precise machining.
