Craftsman Cribsheet No. 109: PMPA Speaking of Precision Podcasts — Engineering and Material Resources
The Precision Machined Products Association offers a variety of resources to its members.
PMPA’s Speaking of Precision podcasts can be found on major platforms or on PMPA.org. The list below of podcast resources for engineering/materials podcasts:
- Steel Basics — Where Do Steel Properties Come From?
- How PMPA Helps Members Deal With Their Current Material Challenges
- Cold Work, Work Hardening and Your Precision Machining Shop
- 6 Reasons Why Cold Finish Bar Straightness is Perishable
- Yield Loss in Your Shop
- What is Machinability?
- Discussing the new Outokumu Machining Handbook
- Six Factors of Tool Life
- Mailbag Edition - Steel
- How Sulfur and Manganese Improve Machinability
- Heat Treaters — What to Look For
- What You Should Know About Leaded Steel
- The Secret to Understanding Steel
- Different Types of Wear in Your Shop
- Lead Exemptions Under RoHS
- What is the PMPA Mastery Program?
- How Highest and Best Use Can Improve Your Shop
- 5 Advantages of Cold Drawn Bars
- Heads-Up on Lead
- What is Expected of the Part?
- Why Tool Life Can Vary: Carbon and Alloy Steels
- Difficulty Machining: Is it Really a Shop Problem?
Access to all PMPA Podcasts
Access to PMPA Knowledge Centers: Engineering — Materials Resources
‘Can You Hold This Tolerance?’ Is Not An Engineering Question
Keeping It In The Family — Succession Tips From Those Who Lived It | Part 1
PMPA members share some tips to avoid getting burned when passing the business torch from one family member to another.
