Updated Published
Learn the Facts about Leaded Steel Bars
As more applications and newer technology move toward non-leaded steel applications, I thought that a brief refresher about lead and its role in shops might be timely.
The 0.15- 0.35 weight percent of lead contained in these bars helps them machine 25 percent faster with less power required.
Leaded steel bars historically have been a mainstay raw material in the screw machining industry. As more applications and newer technology move toward non-leaded steel applications, I thought that a brief refresher about lead and its role in shops might be timely.
  • Leaded steel bars are standard steels and widely available. In the U.S. 12L14 is the predominant grade. 11SMnPb30, 11SMnPb28, 9SMnpb28, and 9SMnPb36 are German designations nominally equivalent to 12L14. The Chinese version of 12L14 is Y15Pb; Japanese nominal equivalents include SUM22L, SUM23L and SUM24L.
  • Leaded steels are selected for use for the savings achieved in producing parts by machining.
  • Leaded steels are not appropriate for all parts, and parts with low amounts of stock removal may not create any noticeable savings.
  • Today’s leaded steels are more consistent, more uniform, than they were when produced by the ingot process.
  • The decision to use leaded steels for a specific part must be based on the economics for that part—volume, stock removal, part complexity, tolerances required, surface finish needed are all factors that contribute to that economic calculation.
  • There is no sacrifice in mechanical properties when adding lead to steel. Neither longitudinal nor transvers mechanical properties are affected by the addition of lead to steel.
  • Leaded steels are currently permitted under European Union regulations covering End of Life Vehicles, RoHS.
  • The reduction in energy required and time needed (about 25 percent!) to machine a part make leaded steels environmentally friendly by reducing carbon dioxide emissions to create parts compared with using unleaded materials.
  • In order to be dangerous to humans, lead must be in a soluble form. The lead in steel bars is a separate solid phase. IARC lists lead under its Group 2B category, “possibly carcinogenic to humans.”
  • Lead, as well as chromium, copper, manganese, nickel, and phosphorous is required to be reported under Sara 313 (40 CFR 372.65) when they are above established thresholds.
Originally posted on PMPAspeakingofprecision.com blog.
See also:
Rapid Methods for Determining the Weight of a Steel Bar (Imperial Units)
