NDK Paragon’s Chief Technical Officer and sole machinist Nick Katrov programs and runs a machining simulation with HyperMill. Source (all images): Open Mind Technologies
It wasn’t only a desire to be a one-man operation in a machine shop that drove Nick Katrov to start his own business. In addition to acquiring the machinist experience early on in his career, he also grew into management roles at well-known machine tool manufacturers and distributors over the years, where he interfaced with major industry players such as General Electric, Pratt and Whitney, Rolls-Royce and Bombardier. “It was a great run, but I had enough of the corporate world and I didn’t want the easy way out,” Katrov says. “So I decided to get back to my passion of cutting metal again.”
Katrov is the chief technical officer and sole machinist of NDK Paragon, a 3,800-square-foot operation located in Oceanside, California. The shop is co-owned by his wife, Tina Torabi, who is the CEO. NDK Paragon serves the aerospace, semiconductor and medical industries, and Katrov uses three CNC machining centers for its complex jobs: two Mikron five-axis models — one of which has a seven-pallet system tuned for lights-out manufacturing — and a three-axis VMC from DN Solutions. He also uses a Hexagon CMM with full scanning capability.
As a job shop with high-mix, low-volume orders, precision, accuracy and reliability are paramount. “All of our applications require very fine surface finishes of better than 8 microinches Ra, in addition to high dimensional and true position tolerances with tenths-level accuracies,” Katrov notes.
Tackling Complexity with CAM
Working on complex parts in this high-precision environment, especially in a one-machinist shop, required a robust, reliable CAM platform to drive key high-performance, five-axis machining strategies. Katrov found this platform in Open Mind Technologies’ HyperMill, a CAM software system with one postprocessor for maximum process reliability, minimized machining times and cost efficiency.
The shop’s CAM software includes support for five-axis cavity milling.
“With our applications requiring full five-axis strategies, we have successfully utilized most of the five-axis modules in HyperMill, such as contouring, tangent milling with barrel cutters, swarf milling and helical drilling,” Katrov explains. He says he was particularly impressed with the simplicity and seamlessness of the CAM software for programming complex jobs. On top of that, he says the part simulation saved setup time and reduced scrap on account of its accuracy. HyperMill’s reliability enabled Katrov to focus on daily tasks in the shop, secure in the knowledge that the software would work properly.
Saving Money with Standard Tooling
Utilizing tangent milling with barrel cutter strategies from the HyperMill Maxx Machining performance package has enabled the shop to manufacture very complex components with standard tooling, which has reduced cycle times by as much as 70%, Katrov says. “And there are times when this tangent milling with barrel cutters feature provides the only way to effectively machine the required shape of a customer’s part,” he notes.
In addition to tangent plane machining, Katrov also relies on other HyperMill features for time and tooling cost savings. One such feature is five-axis helical drilling, which enables him to use regular end mills to helically drill large holes at high feed rates. A high-precision surface module, which enables him to mill fine surface finishes, and advanced part probing cycles for the Heidenhain Control have also enhanced Katrov’s operation. “Open Mind Technologies postprocessing is clean and accurate. We have never needed to make manual edits to make the programs run properly,” he says.
Five-Axis Strategies
The HyperMill CAM software suite includes a wide range of five-axis strategies designed for machining challenging geometries, free-form surfaces and deep cavities at maximum efficiency levels. Users can choose between five-axis machining with a fixed tool angle, automatic indexing or true simultaneous machining. All tool paths generate fully automatically with collision checking and avoidance.
All five-axis tool paths generate fully automatically with collision checking and avoidance.
The performance package of the HyperMill Maxx Machining offers three modules for drilling, roughing and finishing that are designed to help users achieve optimal rates of machining productivity. According to Open Mind Technologies, five-axis helical drilling uses standard cutters to open large areas prior to roughing and applies a five-axis helical tool path to efficiently remove material and evacuate chips. The roughing module includes cycles for milling spiral and trochoidal tool paths. It also offers options that identify large inscribed rectangles or circles within components to optimize machining with simple tool paths and complete the pocket by identifying the regions with remaining material. Dynamic feed rate adjustment according to actual cutting conditions are said to ensure consistent milling at the highest possible rates. The package also supports high-performance roughing of both prismatic and curved component faces with five-axis techniques.
Algorithms in HyperMill CAM software are designed to provide continual removal of a constant chip volume. According to the company, this delivers high utilization rates without exposing the tool to undue stresses, resulting in roughing speeds up to 70% higher than conventional milling.
Open Mind Technologies says its HyperMill five-axis tangent plane machining enables cycle time reductions of up to 90% when used with conical barrel cutters. In addition, stepover widths of 6-8 mm or more are possible with the large radii of conical barrel cutters, resulting in smooth surface finishes and improved tool life.
Read MoreSolidCAM Conference Live Stream Will Feature Latest Updates
The annual SolidCAM World conference will be live streamed on September 5-6, 2023.
Read MoreGibbsCAM 2023 Includes Sandvik Coromant’s PrimeTurning Strategies
The software’s PrimeTurning Strategies are said to permit turning and facing in all directions, which is said to deliver dramatic increases in high-volume production.
Read MoreVericut 9.4 Offers Increased Connectivity Across Manufacturing Workflow
The latest version features a new module, CNC Machine Monitoring, which connects Vericut directly to CNC machines and streams data to enable users to monitor what their machines are doing on the shop floor, live in real time.
Read MoreMicromachining Fundamentals
Read MoreCraftsman Cribsheet No. 126: AISI System of Identification
Source: PMPA Prior to the Society of Automotive Engineers taking responsibility for Steel Grade nomenclature in the United States (1995), the American Iron and Steel Institute determined U.S. standard steel grades in collaboration with SAE.
