Microbore Collets for High Clamping Force
The powRgrip PG system uses a toolholder and collet to generate a high clamping force while still maintaining a TIR of less than 0. 0001". The company says it takes less than 10 seconds to press in a tool or remove it from the holder.
The powRgrip PG system uses a toolholder and collet to generate a high clamping force while still maintaining a TIR of less than 0.0001". The company says it takes less than 10 seconds to press in a tool or remove it from the holder. Because no heat is used, tools can be used immediately after a tool change.
The system is especially useful for high-speed machining applications. In cycle testing, the system exceeded 20,000 insertions and removals.
Interchangeable collets are available from 1/8" to 1", including metric sizes, and will hold both carbide and HSS tools.
Coolant-Through System, Toolholders for Improved Efficiencies
Eastec 2023: The reCool retrofittable reCool coolant-through system converts existing flood-cooled driven tools on turning machines to through-tool, coolant-capable in as little as two minutes, while the powRgrip high-precision toolholding system is said to generate extremely high clamping forces equal to or higher than shrink-fit holders.
Seco Tooling Lineup Promotes Optimized Part Processing
The company’s expanded tooling lineup is aimed at applications ranging from general ISO turning to high-volume hard turning and deep-hole drilling.
Tips for Choosing the Right Toolholder for High-Speed Machining
