Reid Supply
round bar
Rounds are sometimes mistakenly thought to be the easiest to straighten and are frequently the subject of customer complaints. However, symmetrical shapes are in fact the easiest to straighten.
To some extent, bar straightness is like the air we breathe – you only really think about it when it is polluted or not there at all.
In my nearly half a century of experience in manufacturing, most of which has been associated with the production and use of metal bars for machining, I have learned that bar straightness is a property that can be critical to a successful machining operation. The absence of adequate bar straightness can create a variety of issues, notably bar misfeeding problems, out-of-tolerance parts, excessive noise, premature machine wear and tool breakage. Those of you who own or manage a machine shop know this all too well.
Obviously, some machining processes are more sensitive to bar straightness issues than others. Those operations whose feedstock is a coiled rod or bar have mechanical design features that straighten or hold the material as part of their initial feed mechanism.
However, many operations require a high degree of bar straightness, especially when the material is to be presented to a machine by a bar feeder. For that sector of the market, the following is a brief review of the steps your bar supplier can take to ensure positive results. This discussion applies equally to all materials, including aluminum, brass, bronze and steel. Plus, it arms you with questions you can pose to your material supplier if straightness issues arise.
There are basically three types or configurations of straight barstock used as raw material for making machined parts: round stock; standard and symmetrical shapes (hexagons, octagons, squares); nonsymmetrical special shapes (double D, teardrop, key, twin lobe). Each type requires a different approach in its manufacture to ensure adequate straightness for the machining customer.
Opportunities to control (or ruin) bar straightness exist at eight stages of manufacture and delivery:
  1. Original hot working process (rolling or extrusion)
  2. Cold drawing process
  3. Final finishing (or straightening)
  4. Collecting and bundling
  5. Bundle handling and storage
  6. Shipping
  7. Unloading and storage at customer’s facility
  8. Loading bars into the customer’s machining process
Simply having proper standard operating procedures in place to ensure the bars are consistent right out of the drawing die is the key to supplying straight round stock, particularly cold drawn material. Subsequent “straightening” operations on rounds control internal stresses rather than absolute straightness. For example, leaded alloys can increase in diameter after aggressive straightening in two-roll operations (for example, on Medart or Mecco equipment). Control of such internal stresses can also be a deal breaker in nonleaded materials when the stock is machined asymmetrically – as when machining automobile steering racks, where one side of a round bar is selectively removed, potentially exposing the internal stresses that can result in bent finished parts if the effect of such stresses is not well understood and controlled by the bar supplier.
Rounds are sometimes mistakenly thought to be the easiest to straighten and are frequently the subject of customer complaints. However, symmetrical shapes are in fact the easiest to straighten. The bars must exit the cold finishing die straight. This simple notion requires a thorough understanding of the drawing operation by the bar supplier and the “management will” to develop proper techniques and control the process meticulously.
Nonsymmetrical shapes can be a challenge, but the key to providing a straight bar for the customer is manufacturing consistency. In many cases, the extrusion or the drawing operations have developed a technique to produce a slight but consistent bow, which when presented to the final straightening operation gives the opportunity to exert a consistent corrective pressure resulting in a straight bar.
Operations that focus on aggressive straightening only afterward often fail to appreciate the extent to which the product straightness can be controlled in extrusion or drawing. Control of straightness after the manufacturing operation is fundamentally about avoiding postproduction damage. Careful design and operation of bar handling, bundling, packaging, transportation, loading, unloading and storage often simply using basic common sense will go a long way toward ensuring that the product maintains its straightness right up to the point when the machine tool engages the bar in the customer’s facility.
About the Author
Roger Bassett
Roger Bassett is a retired company president and university professor who has enjoyed a more than 40-year career in the metals industry. He is currently assisting Franconia Industries and Diehl Brass Solutions with their business development. Bassett has served the Precision Machined Products Association through the years, holding many leadership positions and speaking at local and national meetings. Contact: 586-212-5122 or bassett@tm.net.
Reid Supply
Bar Feeder for Sliding Headstock Lathes Enables Higher RPMs
PMTS 2023: The LNS GT 342 automatic magazine bar feeder is designed to enable fast and easy diameter changeovers and improved productivity.
Bar Feeders
Bar Feeder Offers Simple, Fast, Silent Automation
PMTS 2023: Bucci Industries’ Next 25 bar feeder offers high rotational speeds (more than 10,000 rpm) and fast, unattended bar changes with high indexing and silent performance.
Craftsman's Cribsheet No. 78: Straightness of Cold Finished Steel Bars
The straightness of cold finished steel bars, and all other barstock for our machines, is of critical importance.
Bar Feeders
Bar Feed Considerations For High-Speed, Lights-Out Machining
There are design elements incorporated into today’s 12-foot, magazine-load bar feeders that make them more useful for high-speed and untended operation. This article looks at some aspects to consider before purchasing a 12-foot bar feeder.
Reid Supply
