Why Tool Life Can Vary: Carbon and Alloy Steels
Despite the use of our best technology and our efforts to control our processes, tool life can vary when machining carbon and alloy steels.
Here are six factors that can affect tool life in your shop.
1. Variations between suppliers. Even though the grade is the same, suppliers’ melt processes, scrap practices, melt recipes and reduction in cold-drawing and straightening practice can signifi cantly affect chip breakage, resulting built-up edge on the tool and the surface fi nish differences.
2. Variations in chemistry. With a potential subset of variations between suppliers, the fact is that a plain carbon grade with 0.005 weight percent sulfur will not machine like a material with 0.025 weight percent sulfur.
3. Variations in grain size. While this factor is typically more relevant in stainless steels, when machining forgings, blocky structures resulting from excessive temperatures can result in inconsistent machining performance.
4. Variations in microstructure. In this case, it is not so much about the grain size as it is about the present structure. This is particularly problematic in the ~0.40 weight percent carbon alloy grades such as 4037.
5. Decarburization or scaling on the work surface. Decarb can result in a carbon-poor, gummy surface, only to transition into a fully carbon-containing microstructure. Scale on the work surface can result in excessive tool wear because of the high hardnesses of the various iron oxides that may be present (hematite, the red oxide of iron, Fe2O3, has a microhardness of approximately 1030 DPH).
6. Deoxidation/high inclusion count. Free machining grades such as 12XX and 11XX steels are typically sold to a “coarse grain practice” with no deliberate additions of grain refiners or deoxidizers. Sometimes, you may fi nd deliberate additions of silicon to 1144 in order to improve the internal soundness of the steel. The resulting silicates can abrade the edge of the tool when running at the
surface feeds expected for re-sulfurized steel. The addition of aluminum as a grain refi ner
can cause rapid edge wear as well. Rarely, one might encounter exogenous inclusions entrapped in the steel from melt and casting. These can be real show stoppers.
Takeaway: Purchasing the same item from different suppliers hurls the range of global variation at your machining operations. Standardizing on a single supplier for an item will allow you to get to a steady state in your process.
