powerShrink 600
Cody Mitchell, territory manager at Zoller, gives a demo of the powerShrink 600. The shrink-fit tooling system uses coolbyLight operator guidance that enables an operator to know when the system’s toolholders are cooled to a safe temperature via a green light illumination. In addition, the cooling bells are labeled with the corresponding tool diameters. Photo Credits: Production Machining
As all manufacturers strive to improve productivity with fewer skilled workers on the shop floor, there are suppliers in the industry providing solutions that not only create efficiency but also require less of a technical skill set to run the equipment. In other words, they are supplying shopfloor workers with smart equipment that basically shows an operator how to use it — in some cases with a light signal – without any training or referring to a manual.
Zoller, for example, is a company whose vision is to offer smart manufacturing via its digital network, automation and ease-of-use built into its products. This manufacturer of presetting, measuring devices and tool management software held its Technology Days and Open House Event May 9-11, at the company’s U.S. headquarters in Ann Arbor, Michigan, where it highlighted its latest products with new interconnectivity capabilities.
I attended the event on May 11, which focused on “CAM to Part — the Entire Process Chain of Zoller Solutions” that day. Along with browsing the facility’s showroom which featured its latest technologies, I sat in on presentations given by company experts, including a keynote from company president, Alexander Zoller. Also, Scott Volk, Metalquest (located in Nebraska and Idaho) machine shop executive vice president and COO, discussed how partnering with Zoller has improved its production efficiency.
Presentations by Zoller employees described how Zoller is creating its products to enable departments in a manufacturing facility to talk to one another in a virtual sense. The company’s TMS (Tool Management Solutions) can provide a single-source database as well as a tool storage system, data transfer, tool monitoring and toolholders that are all interconnected.
Implementing such a system is said to supply machine shops with more efficiency because it forces programmers to use a specific set of tools that are equipped with a Zoller ID chip. This ID chip contains a QR code on the toolholder that enables tool traceability. Traceability offers many advantages for a shop, including tracking tools back to the machines in which they were used, tool life visibility and more.
The company showcased its many presetting and measuring equipment models at the open house event held May 9-11, in Ann Arbor, Michigan.
With the ID chip in place, an operator only needs to scan the barcode to retrieve the tool’s information from the TMS database. The chip also extends communication with machine tool interfaces, including FANUC and Heidenhain CNCs and soon Siemens CNCs as well. With this capability, further integration is possible for Industry 4.0 technology.
The tool storage demos for the company’s Keeper and ToolOrganizer smart cabinets in one presentation caught my attention because of the lighting on these cabinets that was used to signal to an operator the location of the tools needed.
This tool storage unit from Zoller is a combination of several units that contain lights to signal to the user/operator where the tooling and assemblies are located within the system.
For example, the demos showed an operator reviewing the setup sheet on a monitor that reveals which tools are out of stock. Then the drawer that contains the replacement tool components in the ToolOrganizer cabinet lights up to show its location. Once he/she has those components, the operator opens the Keeper door that is again lit up to signal to the operator where the assemblies are located.
The headquarters’ showroom also included the Hyperion and Smile presetting and measuring machines, which are both for turned part production.
Kyocera SGS
GWS Tool Group
Tungaloy-NTK
Toolholders
Machining’s Impact on Sustainability
Individual elements of the machining process such as machine tools, tooling and even CAD/CAM software play a role in overall machine shop sustainability. Observing the entire process especially when it comes to their influences on energy usage is key.
Toolholders
Seco Tooling Lineup Promotes Optimized Part Processing
The company’s expanded tooling lineup is aimed at applications ranging from general ISO turning to high-volume hard turning and deep-hole drilling.
Toolholders
Coolant-Through System, Toolholders for Improved Efficiencies
Eastec 2023: The reCool retrofittable reCool coolant-through system converts existing flood-cooled driven tools on turning machines to through-tool, coolant-capable in as little as two minutes, while the powRgrip high-precision toolholding system is said to generate extremely high clamping forces equal to or higher than shrink-fit holders.
Toolholders
Tips for Choosing the Right Toolholder for High-Speed Machining
Single & Multi-Spindles
Video: Machine Shop President Explains Advantages of Tool Presetters
When contract shop MetalQuest purchased its first multi-spindle, it also purchased a dedicated tool presetter for the machine. Learn why the company president feels shops of all sizes can benefit from measuring tools offline.
