The ABCs of a B Axis
The B axis on a machine gives operators the ability to manipulate a tool to any angle in precise increments.
The B axis on a machine gives operators the ability to manipulate a tool to any angle in precise increments. It is capable of moving in an arbitrary five-axis plane rather than being restricted to the traditional live tool motions found on a Swiss machine, where a milling cutter can be positioned axially to either the diameter or the face of the part.
Sometimes, the B axis is the rotation of the milling head. On other turn-mill machines, though, the linear motion that enables a second spindle or subspindle to approach the main spindle for a workpiece pick-off is referred to as a B axis.
The B axis is best suited to machine complex geometry parts in lower volumes. Complex parts can be machined in one setup by using the B axis cutting capability, which helps avoid the need to spend a lot of time reconfiguring the tool zone to accommodate a different part or particular machined feature. This is especially useful in the medical industry, where sculpted, low volume parts are often machined.
To read about one OEM’s multitasking center with a B axis, visit “Machining Complex Workpieces Complete.”
For more information about the B axis, read “The Buzz about the B Axis.”
A New Approach to CNC Turning
This turning process takes advantage of a turn-mill’s B-axis spindle to vary a tool’s approach angle to optimize chip control and feed rates.
Adding 5-Axis Capability to a 3-Axis CNC Mill
This attachment provides shops using thee-axis machining centers the option of on-demand four- and five-axis machining.
Get 5-Axis Machining on a 3-Axis VMC
Machine shops want and need to eliminate steps in the manufacturing process. Adding four- or five-axis capability to an existing three-axis VMC is a practical way to achieve five-sided machining using a single setup.
