Chip clogging is a common cause of chip conveyor issues. However, this Hennig unit installed on a turning center at Cookeville, Tennessee’s Custom Tool, features conveyor teeth that enable it to better handle long, stringy chips created during some turning operations. (Photo Credit: PM)
There are various reasons why a machine tool’s chip conveyor isn’t functioning as it should, a prime one being a clog of excess chips or other material. In some cases, a shop can fix the problem itself. Other situations might require assistance from the chip conveyor manufacturer. What follows is advice from Hennig, manufacturer of chip management, machine protection and facility safety equipment, to troubleshoot conventional chip conveyors if a problem were to arise.
To start, safety comes first if you choose to have your maintenance personnel look into the problem. Be sure electrical power to the chip conveyor is off. If your personnel is not familiar with the system or hasn’t performed maintenance on such devices before, it’s recommended you contact the manufacturer so as not to risk injury or even death.
When getting started on your own, it’s first important to identify what issue your chip conveyor is experiencing, which could be related to the power supply, motor, drive, rails, frame or belt.
First, run the chip conveyor in reverse to determine if the unit is getting electrical power and the motor is functioning. If the motor is not functioning even though electrical power is being delivered to it, unbolt it so the manufacturer can check if it’s running properly. After unbolting the motor, you’ll also want to remove the motor from the driveshaft to check driveshaft condition. In a chip conveyor such as a Hennig unit, you’ll be able to locate two sprockets, one driveshaft and three keys to do that.
And, while your first thought might be to repair a bad motor yourself, it typically makes more sense to replace the motor and gearbox. Motor replacement cost typically starts at $1,200, although it’s recommended to contact the chip conveyor for an accurate quote.
On the other hand, a functioning motor is generally good news. If your motor is still running, you could have a ball of chips, cutting tool or finished part jamming the unit. Clear any obstruction and test the chip conveyor to determine if that was the problem.
If your motor is still running, you could have a ball of chips, tool or finished part jamming the way.
If that doesn’t remedy the situation, run through this checklist to identify the potential problem(s):
- Check for worn drive elements such as sprockets, sprocket keys, motor key and driveshaft. Replacement parts can be ordered from the chip conveyor manufacturer.
- Try moving the belt by hand. Cranking the driveshaft with a wrench can help you identify if it’s an electrical or motor issue. If your chip conveyor is still moving, it probably means the motor must be replaced.
- If the belt can’t be moved by hand, examine the belt assembly. One of the most common chip conveyor issues is a shaft that has pulled out or has become bent. This typically happens because the crimp on the shaft of the belt is worn. The belt will become jammed when the side link where the shaft has been pulled back has fallen and causes a jam where the belt turns a corner.
- If you’re able to run the chip conveyor in reverse, move the damaged shaft up to the discharge end so your maintenance person has access to the shaft to perform the repair. Once you’re able to access the damaged shaft, remove it by grinding off the crimps to separate the belt. You’ll want to purchase a conveyor hinge kit to replace the damaged hinge.
- If you’re unable to run the conveyor in reverse, locate any shaft you’re able to access and grind off the crimps to divide or split the belt . Once the belt has been split, you can attempt to remove the belt from the chip conveyor.
- If you’re unable to remove the belt, grind the belt shaft crimps. Use the coolant slots as an access point to gain some movement if your conveyor has those slots. You’ll need to purchase a hinge kit to replace the damaged hinge.
- If you have only a few damaged shafts or hinges, purchase a hinge kit to get your chip conveyor in working order. If there are multiple problems with your belt (traditionally when there are issues with more than 20% of the belt), it might be time to order a replacement belt as well.
- Examine the chip conveyor’s frame and rails. Damaged rails can prevent the belt from traveling properly. Take a close look at the chip conveyor for signs of wear such as holes, grooves, dips and so on. Any of these signs of damage can lead to larger issues, including motor and belt failure. If you’ve identified any significant damage to the frame or rails, it’s likely time to replace the chip conveyor.
Unattended Production Takes More Than the Most Capable CNC Machine
Read More4 Bright Ideas for Effective Lights-Out Machining
Read MoreInside the Premium Machine Shop Making Fasteners
Read MoreReinventing the Wheel with Robot-Automated CNC Multitasking
Vertical Integration Enables Rapid Manufacturing Response
For this contract manufacturer, having myriad machining and manufacturing capabilities in-house enables it to deliver assemblies to customers faster and with higher quality.
Read MoreShop Shares Lights-Out Lessons Learned
Automated machining and data collection have helped Custom Tool to not only grow its business through more overnight production but also to establish a continuous improvement mindset that has enabled it to become more efficient in numerous areas.
Read MoreRW Screw: Where Automating Processes is a Common Thread
This Northern Ohio contract machine shop increasingly integrates automation, in all its forms, as it adapts to the reality of a continually diminishing talent pool.
