Precision Machining Technology Show/PMTS
If you attended this year’s PMTS, what caught your eye? Was it some element of automation? How was your experience? Email me at dkorn@productionmachining.com to let me know.
In the precision machining world, the term “automation” typically evokes images of robots tending machine tools. Robotic automation certainly has had a big impact on shops facing a shortage of skilled workers as well as those looking to perform long stretches of unattended machining (in some cases, lights-out, overnight). For example, the article on page 30 describes one shop’s story integrating its own robot that eventually was paired with a pallet-changing VMC for a high-volume job drilling stainless steel tubes. Interestingly enough, the robotic automation came before there was work for it to support. In addition, the article on page 26 explains the advantages of having a robot integrated inside a CNC turning center. This design not only offers advantages (such as reduced floor space) but also improved chip evacuation using the robot to direct a coolant stream at the point of the cut as well as using the robot to help support long workpieces during turning to minimize chatter.
Was automation on your mind at PMTS?
However, there are myriad other forms of automation that shops can leverage to their advantage even beyond bar feeders, the most common means to automate a CNC turning center. Many examples were evident at the recent Precision Machining Technology Show (PMTS) held last August in Cleveland, Ohio. Here, we describe five: automated data collection from all CNC machines in one exhibitor’s booth, vacuum parts collection, 3D part measurement, tool presetting and parts cleaning process monitoring.
Additive
Automation
Sponsored
Basics
4 Questions About Cobot Integration
Many shops appreciate that cobots are easy to program and enable collaborative operation, but there might still be questions about how to install them.
Bar Feeders
Making Waves with Lathe Automation
After years of relying on an extensive machining cell for part production, this marine equipment manufacturer has now reduced part handling and improved quality through use of single-setup lathes and automated loading and unloading.
3D Printing Creates a Window of Automation Opportunity
For this Omaha shop, periodic part inspection required an automated turning cell to pause production. Printing a plastic parts collection chute for delivery outside the cell solved this problem, and it turns out the shop has found 3D printing to be valuable in many other ways.
